How about listing what you've done so far...jstoumba said:
How about listing what you've done so far...jstoumba said:Before I get too many critics I will say this I have done many many things to diagnose this already many very extreme but no one's perfect so I'm open to all ideas even if I've tried them...
Would think that would cause a misfire though? I mean it's an easy swap
Well im thinking I'm going to swap them tomorrow for a set of Id's just too see what happens might as well at this pointMine never misfired.. sometimes they would dump a ton of fuel, some times none at all. It would be lean, so I would go into the map and add more fuel, and it would be even more lean... or, the AFR would be just right, then suddenly it would be super rich at the same load/rpm that it was fine just a minute ago. DW would only offer replacements, so I would send the injectors in, they would test them, verify that they weren't working right, then it would be 4-6 months before they would send me the replacements (they said because they were constantly backed up with a very large number of returns). I would get the replacements and it would do the same thing.. or the opposite. I spent two years with them replacing non-working injectors with other non-working injectors before I started raising hell about it. Finally they agreed to give me a refund since it was obvious that their injectors simply did not work.. then it took another 14 months for them to actually get the money back to me. In that time period I knew five other people with the same injectors, and every one of them suffered injector failure within a six month period, two of them resulting in catastrophic engine failure. I'm convinced they were just taking the non-functional returns and shipping them back out to the next person.
As soon as I put some PE injectors in it all the AFR issues were gone.
Never heard of power enterprise eitherI'm guessing you are talking about Power Enterprise (PE) injectors? Never really heard of them, or read much about them. Do you think they are as good, same, or better than Injector Dynamics injectors?
