I would personally not do anything besides leave everything entirely stock for a good while. I would not have an intake, exhaust, intercooler, anything.
My tips for break in are pretty simple. Don't beat the engine to death, try to keep out of boost, accelerate normally without giving it tons of throttle. Don't use cruise control, and try to keep the rpm varied a bit. So if you have a long drive on the highway at 65, vary your speed a little to keep the engine from sitting in the same rpm for long periods of time, or if your going slow enough 55 or so maybe drop down to 4th for a few minutes then back to 5th. Its also really important not to lug the engine, even more so when new and under break in.
Its also extremely important to keep an eye on the oil and fluids. Keep in mind dark oil is normal, and does not mean there is a problem. Coolant levels are very important as well. You need it to maintain the correct temperature.
2014 is pretty new, what happened to the previous engine?
