1 - 3 of 3 Posts
It just resets the realtime map you are running from what I understand. I dont think it even gets rid of any of the learning the ECU has done. Someone correct me if im wrong, good question though. Hopefully someone who knows more can reply.
You are fine. It does get rid of what your ecu has learned though. Whenever I reset my ecu with my cobb vf34 map I do the quick ecu learning trick. From what I can remember you need to go somewhere on a road that is long enough and flat enough that you can hold the rpm's at 2,500 in 3rd gear with 2-4psi for 5 seconds.
Check this thread out...
http://www.clubwrx.net/forums/showthread.php?s=&threadid=17246&highlight=ecu+learning
1 - 3 of 3 Posts
