I don't know how many people have had troubles getting the screw holes to line up right. Or if you get replica fog light covers like I did and the screws being a tad to short. So here is the tip, go to your local auto store and go to the license plate holder section. You should be able to find there some screws that should be the right diameter, and a little longer to make it easy to install. And an even better tip is this.
Find the screwes that use a allen wrench lock. I know some people have had these stolen because all it takes is a flat head screwdriver to get these off. So spend the two dollars and get the lock screws and it will make you life a lot easier.
