1 - 20 of 33 Posts
they said its going to be 4 hours on each side of the car to put new springs on. thats $800 in labor alone, not including the springs. that sounds way to much to put in springs dont u think?
what the ****?
it takes i'd say an hour TOPS.
do not go to this place
go read tutorials on spring install.. rent a compressor and do it yourself for free.. call over a friend to help you.
I did mine in about 2 hours with a friends help. Neither of us had done springs before. Just read a tutorial, borrow a spring compressor from autozone, and do it.
A shop with a lift and air tools can probably do it in less than an hour. I would tell whoever gave you that quote to piss off.
what the f*** is right, that place is a scam, i could see 350 labor at a high end, do some searches and save all your cash. my friend works at a garage he said not that big deal he will do mine in my garage, i have air , impact, but nothing spacial, check around. never take 1 price
wolf
i've done springs on a 350, a 300, an rx-7 (twice) and on my scooby ~4 or so times (lol)
i went:
stock->stech->eibach->stock->prodrive
N
Guest
diy it with some friends. i did mine alone, but it took me forever.
^^ agreeed!! all you need is some wrenches, tools, spring compressor and car stands and a 2 ton jack and a couple extra hands!! i JUST finished doing my springs and only paid 80$ for tools , 30$ for pizza!!
its really not that hard to do, the rough part is the rear! the front is easy!
...agreed, read up, take your time and do it yourself, you will learn more about your car and save some cash.
^^^but why would u say the rear is the hard part?!?? i thought exactly the opposite.
N
Guest
only because you gotta take out the seats, and seat belts ...the front was cake except the bolts were tight as ****!
wunderboy....btw where in jersey are you?? ill come give you a hand if you need help with the install.....i do good work for a six pack ;)
N
Guest
it was cool tho... i still need to take apart the backa gain and fix one of the seat belts, its not in there properly, just spools out not back in! simple enough to fix
I was gonna do mine myself, but i dont have a spring compressor and i found a guy who did for $200 plus he did the 4 wheel alignment right afterwards
N
Guest
i rented em for 55$, i got a 2 yr allignment deal @ tire kingdom..gonna go monday...the prodrive springs are seating nicely i ca notice major drop up front
It took me about 3-4 hours from start to finish with breaks. Not hard to do yourself, and for around your price for labor you could pick up coilovers, with is an easier install.
If you were in Washington, we could've help you. My friends and I did lots of springs.
1 - 20 of 33 Posts
