RalliTEK 5EAT Transmission Mount Insert Bushing installs in your factory transmission mount. RalliTEK 5EAT Trans Mount Insert provides improved shift feel and response. This bushing will insert into your factory trans mount and remove excess drvietran movement caused by soft and/or aging rubber in your factory mount.
Designed specifically for the smaller mount made for Subaru 5 speed automatic transmissions. Requires removal of factory mount from vehicle. Bushing insert installs best with a bench vice. Install instructions are included. Usually takes less than one hour to install from start to finish.
RalliTEK has the knowledge and parts to help you build the Subaru of your dreams.
In Stock Now @ www.RalliTEK.com
4EAT Bushings in stock too!!
