1 - 15 of 15 Posts
So messing around with my AP tuner and notice the dyno feature. Try it and come up with this.
I heard the AP dyno would be off but come on! What gives?
Sent from my SGH-T989 using Tapatalk
Well considering I only have the following performance upgrades:
2011 Wrx premium
Cobb catted stage 2 dp
Cobb sf intake
Grimmspeed ECBS
Ap Stage 2 map
I should def be under 300 bhp, I have a hard time believing this is anywhere close to the truth!
I did debadge recently, maybe the weight reduction did it!
That number is just a joke. Interesting to see it but waaaaaaaaaay off!
yep hard time believing that 500+awhp. my last dyno showed 309awhp and that was a hart breaker dyno, so its probably more like 330awhp. you should go to a real dyno run at a perfomance shop and com pair
2011 Wrx premium
Cobb sf intake
Grimmspeed ECBS
Ap Stage 2 map
You should technically be tuned for that grimmspeed ebcs as well, if you're using Cobbs ots maps, you have to stick to the map notes to a T. Get a protune for the ebcs or reinstall the stock unit
Discussion Starter #13
I took a Cobb OTC Stage 2 SF intake map and reduced the WGDC by 30%, per Grimmspeeds recommendation
Discussion Starter #14
What mods are u running? Wrx or Sti?
1 - 15 of 15 Posts
