1 - 3 of 3 Posts
Cheeky Bastage!
I have a 2009 wrx. I had installed a cobb short throw shifter with bushings about a year ago. I noticed that when shifting into third it would grind a little bit, not sure exactly which part was grinding. I removed it only a few months later bc I didnt like that.
a. what would cause it to grind like that?
b. could this grinding have been a cause in the premature wear on my clutch? (replaced at 30k)
If installed properly, the shifter would have nothing to do with that. But what may have caused your clutch to wear out so quickly, could have also caused the grinding.
Pro Manscaper
Telling you Zach...get a new WRX :p
1 - 3 of 3 Posts
