1 - 10 of 10 Posts
Hey all Chicagoans! Does anyone know a reputable place to do my 30K service at, except Subaru dealers as they charge too much.
:rolleyes:
Personally I'd be willing to pay a little more for someone to do necessary maintenance at 30k when they know what they are doing... (the dealer)
Perhaps there is a special Subaru shop in Chicago that'd do it, but I do not know of one.
Youre right,and I`m all for someone that knows how to work on our cars but I cant justify spending about $800 for that service. I might just let a shop,just do the brakes and the coolant and handle everything else myself.:rolleyes:
Boba Fett
Every 3,000 miles or
three months
Change engine oil and oil filter
Check tire pressure and condition
Check transmission, transaxle, brake, clutch (if applicable), washer and radiator fluid levels
Every 6,000 to 9,000 miles or six months
Beginning at 22,500 miles
All 3,000 mile services, plus:
Adjust clutch and hillholder (if applicable)
Rotate tires
Every15,000 miles or every 18 months
Rotate tires
Change air and fuel filters
Service fuel injectors (beginning at 45,000 miles)
Test emissions system
Change automatic transmission fluid (if applicable)
Check brake linings
Adjust parking brake
Check C.V. joints
Inspect exhaust system
Check coolant protection level
Check engine component drive belts and adjust as neccessary
Inspect cooling system hoses
Lubricate lock cylinders
Check exterior light bulbs for proper function
Check windshield washer and wiper operations
Every 30,000 miles or
three years
All 15,000 mile services, plus:
Change gear oil
Flush and service cooling system
Change brake fluid
Tune engine
Change spark plugs (2.5 L and SVX at 60,000 miles)
Perform induction & intake system service
Clean throttle assembly and linkage
Adjust carburetor (if applicable)
Change distributor cap and rotor (if applicable)
Engine compression check (2.5 L and SVX if applicable)
Set engine timing
Check engine computer for fault codes
Test/service battery
Adjust ECVT switches (if applicable)
Discussion Starter #9
Hey Chickencow,have you heard of any fluid change days for Chicago just like you guys have up there in Wisconsin?
1 - 10 of 10 Posts
