1 - 14 of 14 Posts
What should I get, 215/40/17 or 225/40/17, and why? I realize the 225 is just to ensure the rim will not crack as easy, but other than that what is the big diff.?
Thinking Man's Engine
Total Diameters:
OEM= 205/55 r16: 24.88 inches
215/40 r17: 23.77 inches
deviation: -4.46%
225/40 r17: 24.09 inches
deviation: -3.16%
Conclusion: your actual speed and mileage will be higher than the speedometer and odometer.
I recommend:
215/45 r17: 24.62 inches
Deviation: -1.04%
225/45 r17: 24.97 inches
Deviation: +.036% (Closest to the OEM tire size)
more responses on this, anyone? am looking at 225/45r17's for my wagon... probably bfgoodrich comp t/a kdws.
Tire Rack
If you check out the tires on the Tire Rack website, they have all the overall diameters for all of their tires offered....Since I have 18's (with no tires yet), I'm opting for the Sumitomo HTR+'s, they have the closest overall diameter (25") to the OEMs...
Does anyone see a problem going with RE 950's 235/45/17 on 17" Prodrive P1's or 17" Supperlegga's? They only offer the tire in 235 or 215, and I think 215 would be too small. Why can't they just offer a 225. I would go with the S-03's but I have to deal with the winters in Washington D.C.
hmmm, the tirerack and coming up with 225s for the WRX wagon, even the S0-3s. on 17" rotas, is a 225 (S0-3 or otherwise) going to rub?
God doesn't
Similar question
I was just reading this thread and I had a similar question. I have an 02 WRX wagon and just bought 18x7.5 wheels with a +42 offset. What is the widest tire that will fit without rubbing or requiring fender modification? I have been looking at 225/40 R18 but would go wider if they'll fit. I'm also trying to keep the aspect ratio so as not to mess up the speedo.
Thanks,
Chris
1 - 14 of 14 Posts
