Welcome. I think you need to go back to the dealer immediately re:shifting issues
Grinding gears is grinding gears. If you did not hear grinding then they were not ground. I, very stupidly, ground gears in my WRX once -- and I definitely heard it! It doesn't matter how the shifter and gear forks are connected (cable or arm) -- if the gears grind you will hear it. As XJman said, you should be fine..... He took the car with me on a test drive and kept trying to force the transmission into first at different speeds......Do you think this tech grinded my gears........Normally you'd hear the grinding as the shifted is directly connected to the transmission by a shaft. But, since the new WRX is connected via cable, it's hard to know if there's an issue going on........Thank you.
Didn't know this and have been driving a stick my whole life. Is this really something you should never do?dont downshift to first.
You can. I was just referring to the old joke Patient: "Doctor, my arm hurts when I do THIS" Doctor: "well then dont do THAT"Didn't know this and have been driving a stick my whole life. Is this really something you should never do?
You need to be good at rev matching to hit it.Didn't know this and have been driving a stick my whole life. Is this really something you should never do?
yea, you sure do.You need to be good at rev matching to hit it.
Sent from my SM-G955U using Tapatalk
Its typically a bad idea from a practical standpoint to do so, unless you are going <5mph.Didn't know this and have been driving a stick my whole life. Is this really something you should never do?
THIS!Its typically a bad idea from a practical standpoint to do so, unless you are going <5mph.
