Resolved:18 WRX driver window switch not operating passenger window after door panel
So all week i have been working at installing some sound deadening to the doors
I did the rears with no issues
Then moved to passenger door, upon completion i noticed i could not control the window from drivers seat, i figured it needed some sort of reset and didn't let it bother me, i moved on and completed the drivers side door installation last night (my doors combined plus under rear seat now have 30lbs of sound deadening combined)
Then after that the auto down feature would not work, as per the manual i found that if you d/c the battery you need to recalibrate the windows which was pretty easy but still i have no ability to control passenger window from drivers switch
Keynotes:
*Removed door panels
*Yes all harnesses are plugged back in
*Harness pins looked all seated, no loose wires that i could see
*Window recalibrate per manual was completed on both drivers and passenger side, auto down now works
*Passenger window not controllable by drivers switch
*Passenger window works on its own from its switch
*Window lock was cycled and seems to be working as it should, it dims out all windows when activated and leaves rear windows and passenger locked and then when unlocked the lights come back on and rears are controllable but passenger side still doesnt work
Can anyone point me in the direction i need to go in? and thank you
Keynotes:
