1 - 5 of 5 Posts
Hey everyone,
Anyone have recommendations to touch up chipped paint on a Brembo caliper?
329116
You can check with Subaru to see if they have any touch-up paint available for the calipers. Honestly, after so many times of the wheel being taken on and off, due to tire rotations, ect, this is bound to happen. I have several of these chips and I just deal with them. No one will notice.
Have you ever removed the caliper pins?
Discussion Starter · #4 ·
It does not really bother me, but I'm just concerned that the chips will get bigger as time goes by. I bought the car pre-owned and this is the only cosmetic issue the car has. Thanks for the recommendation though, I will follow up with them.
I think they're from impact, so I doubt more paint will chip off on its own that hasn't been hit with anything. The top of your caliper was scuffed when someone took a tire off the rim and it leaned in toward the caliper. One of my fronts looks identical in that area. The other two look like impact marks from someone being a little careless when removing/replacing the brake caliper pins, most likely for brake pad replacement.
That paint is pretty sticky. You shouldn't see any more drastic chipping. I'd leave it alone.
1 - 5 of 5 Posts
