1 - 10 of 10 Posts
When im at a complete stop and i go to take off. My clutch or something sounds like its grinding. And the shifts go smooth. But once i speed up and put my foot on the pedal it stutters around 4-5 rpms and then goes back to normal. And i have no idea what it is.
( I have a act heavy duty street clutch btw)
Anyone have any ideas of what it could be?
Super Moderator
Was the clutch broken in properly? Do you launch the car? Why do you need a new clutch on a new car? The factory clutches are quite stout.
As for the stuttering. 4 or 5 hundred or thousand? Need more information to diagnose loosely online. Why not go to the dealer where the car is under warranty?
Discussion Starter · #3 ·
I launched on the stock clutch and it started to slip. Either way wanted to put a new clutch in there. And no its not under warranty anymore. Because i have a cobb cold air and invida n1 exhaust. so im pretty sure that ruins my whole warranty. And yes the clutch was broken in properly. I babied it for 400 Miles. Like act said to do. Didnt start launching the car until i hit about 900 miles on the new clutch. And yes 4k
Discussion Starter · #4 ·
Forgot to mention. The stuttering parts happens past 3rd gear. From 1st to 2nd. It does not do it
Super Moderator
And is the car tuned for that intake?
Super Moderator
Well I'm going to venture you've probably toasted it launching it.
Discussion Starter · #8 ·
Thing is. I know what a bad clutch feels like. Dis doesn't feel like a bad clutch. But I'm gonna have the shop look at it to see what it could be
This happens to me on a cold start. When I cruise while the car engine is still cold and I press the clutch to stop.
It makes a quick grinding/thump noise.
After the car warms up, the noise is gone. :/
Discussion Starter · #10 ·
After the car warms up, the noise is gone. :/[/QUOTE]
I think it's my throw out bearing. I should be getting it done on monday. And have them make sure nothing else is wrong and I will let you know how it goes
1 - 10 of 10 Posts
