1 - 10 of 10 Posts
Car is a 2017 WRX Limited, all stock. There is a weird buzzing or vibrating noise corresponding with engine speed coming from the engine bay. It only happens under deceleration above about 3800 RPM and sometimes has a phase shifting quality to it. Car runs and drives fine otherwise and shows no other signs of abnormality. Its done this since I began going over 4000 RPM after the break-in, since I've had it. See video for example. You may have to turn your speakers up and ignore me yakking about it...
Nothing audible on the video. But I have a similar if not same issue. Only when I drive back roads aggressively for a while do I notice it. On 2nd and 3rd as well but really high in the revs. Nothing noticeable when I do drive regularly to from work with high revs to. I took it to the dealer they weren't able to notice it as well. Again only experienced it when I drive back roads for a little while. I will try record it the next time to share.
Sent from my Nexus 6 using Tapatalk
1 - 10 of 10 Posts
