So I assume you have no factory switch for the fogs inside? Ideally you'd use a relay (i'd put it in the engine fuse box) and only run low power to a new switch. Also I assume you will have to run wires between engine bay and cabin? I would (and have) run TWO or THREE at the time of doing this, in case you want to do any other future mods and not run wires again.
