So my 2016 wrx completely cranked last week for a mere one second before turning back off. Tried jumping it to no avail. All my light and electrical components turn on when I switch the key on, but the engine will not turn over when I try to crank it. Took the battery out, had it tested, bad battery. This was an OEM battery, barely a year old. Replaced it. Same thing. The lights all come on but when I turn the key to crank it, all the lights turn of. It does not even click like the starter is trying to turn. and when I release the key the lights come back on. I tried popping the clutch a few times and it tried to turn over once on one attempt and two times on another (figure I cannot get enough speed).
Friend tapped the starter and it turned over just a few times on that attempt, however when I hold the key to try and crank, I get a wire somewhere burning away its insulation. I just removed the intercooler today to try and get a look at the ground wire and this is what I found. Any thoughts as to what I need to do, is this an electrical problem? I don't think its the alternator but could it just be the starter itself, I'd read a lot of people having issues with the ground wires though not really on the newer cars so soon.
