anyone know if the 17 NON STi Limiteds have wiring for the mirror blinkers and would these just bolt up?
would All I need are the outside STI caps in same color as my car?
On 2015-2017 WRX and STi all models come pre-wire turn signal on the factory door wire connectors. You basically pull your mirror housing assembly off and install the STi housing and plug the into your door harness. You would the mirror caps, led turn signal lamps.anyone know if the 17 NON STi Limiteds have wiring for the mirror blinkers and would these just bolt up?
