wording in my original post is bad. Shouldn't have said backfire, but I just want that loud pop that happens when decelerating.
Then you want to cut out your cats dump excess fuel into the cylinder so it can go out the exhaust. This is bad for your car, is illegal and requires you to tune your car, but have at it. You can also mess with your timing to try and prevent combustion until the piston is already in the power stroke this also lessens your efficiency, power and can cause damage, but it may cause it to burn inefficient enough to do it.
From time to time you'll get it it's just going to happen but if you want it a lot your going to have to do damaging things to your car. It happens in racing because of extreme heat and vast amounts of fuel that don't always have the time to burn off when on a hard braking deceleration.
