2014 STI 18" stock wheel fit a 2016 WRX?
1964 Views 10 Replies 3 Participants Last post by  dorsodurojohn
Seems like it will work right? I'm not good with this stuff, never done it. thanks !!!!
2008+ STI wheels:
Bolt pattern: 5x114.3
Centerbore: 56.1mm
Wheel size: 18 x 8.5"
Offset: +55mm
Tire: 245/40R18
2015+ WRX wheels:
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
Tire: 235/45R17
1 - 11 of 11 Posts
Yup! That will bolt right up
thanks, the guy doesn't want to sell his car without selling the wheels, so good to know. but I lost the wheels.
how about 18x8.5 225x40x18 bolt pattern of 5x114.3???
Yup. you're still good as long as the hub bore is the same size and the offset is right
Enkie evo x gsr this is what I know. 225/40/18 18x8.5 blizzaks 5x114.3
I believe that remained similar across WRXs and STIs.
Acceptable offset is between ~+40 to +56 or so (considering stock is +56)
eh you could use some meatier tires...
Gotcha, just want to make sure since he is now talking about aftermarket wheels I believe.
This is a winter setup only. Yes aftermarket craigslist stuff. trying to match this seller.
1 - 11 of 11 Posts
