Logs:
https://docs.google.com/spreadsheets/d/1RPekpvljuHATVwXasdX4949obaBRjV9h-LfM0Dpdsl4/edit?usp=sharing
So, background. I installed a Cobb downpipe and uppipe using the stock air box and intercooler with a flashed Stage2 93 MTv331 map on it. I was hitting target boost with this setup. See tabs dl14 and dl13 for the data logs.
Now I just stuck on a Mishimoto TMIC with their TB to IC hose. I re flashed the map to start fresh and now I'm not hitting target boost, getting ~16psi. See dl15 tab.
So, do the logs look normal and any suggestions as to why I'm not hitting target boost with the aftermarket IC? The TB to IC hose is fully seated and on their tight, that I know. I do hear a high pitched whistling when it's building boost, but doesn't happen all the time which is weird.
