Is it every start or only cold? There isn't much there to grind unless you are maybe hearing a idler pulley rattle.
Sent from my SM-G955U using Tapatalk
Yes every start just more noticeable when cold especially when it’s 10 degrees in the a.m
If you are comfortable working on the car you can pull the belt and check the tensioners or the alternator bearing.
I can't imagine anything in that area to grind. How many miles?
Edit it doesn’t sound like that and I tested the alternator so now I’m thinking starter or like you said the tensioner
Does it sound like this
https://m.youtube.com/watch?v=yrh4Yi6YOSk
it was my starter about to go. I put a new one one in 3 months ago and all is goodI get the same noise but I've only had it for 10 years or so and I've not worried too much yet. LMK what you find.
