1 - 2 of 2 Posts
Subaru WRX 2012
Hi everyone new to the forum. Im in a bit of a stump here. Yesterday I got out of work started my car up and my check engine light was flashing at me. I ran the codes using my AP and got the following:
P0851 (Neutral Switch Input Circuit Low)
P1152 (02 sensor circuit range/performance (low) bank 1 sensor 1)
P1153 02 sensor circuit range/performance (high) bank 1 sensor 1)
P1518 (starter switch circuit low)
  1. Along with the codes, when the car is in the run position, I can hear the fans switching between 3 different speeds. I believe that’s the car letting me know it’s in limp mode. I tried clearing the codes, disconnecting battery and pressing the brake, and checked all the wiring and can’t find a solution. Any help or insight would be very much appreciated!
Subaru WRX 2012
Discussion Starter · #2 ·
Nevermind. I figured it out! Diagnostic connector was plugged in under passenger footwell.
1 - 2 of 2 Posts
