1 - 9 of 9 Posts
Anyone kno what's causing this code to keep throwing off I'm running stage 2 and I'm getting like 22 pounds of boost !!! How can I fix this it only throws the code when I get into it at high boost
What tune are you running? Are you catless? I'm not sure 22psi is safe. Someone else can chime in there.
With Cobbs OTS tune I had to run the HWG tune bc I was boosting low, and the HWG tune was getting me to 19.
Any other mods?
Just invidia catted dp and cat back aem intake Cobb stage 2 aem 93 I downloaded the lwg and its still dooing it ??????
And a turbo xs rfl blowoff valve could this be the problem ?? I no my car runs rich the lowest I've seen my wideband was 10.3
Discussion Starter #8
I had a.new motor put in it from the dealer the crank bearing went and threw a rod..... Then I put everything on the new motor and this code keeps throwing I tried the stock bypass valve and its still doing it Idk what's going on !!!! I ordered a header wastegate ,solenoid intercooler injectors and fuelpump so I'm not to worried about it because I won't be using the stock wastwgate. And yea I'm calling Cobb tomorrow it shouldn't be doing this only thing I can think of is the cold weather or the solenoid is bad Idk how they really work so .....yeah
The code is from overboosting. your WGDC needs adjusted. Call cobb. They'll help you.
1 - 9 of 9 Posts
