1 - 13 of 13 Posts
NH / 2011 SWP WRX Hatch / 460 whp / 6 speed / Will Cover Shipping* / 10% Finders Fee!
Fully Built SWP WRX Hatch - 460 WHP - 6 speed - Show Car Quality -
Built by Motive Auto Works in MA
Thousands upon thousands of dollars have gone into this beautiful car.
Car drives beautifully. Has been on a 1000+ mile ride without a single issue. Very conservative tune.
Contact: 978-835-628three
Price: $27,500
mileage: 41,XXX
I will cover the cost of shipping the car up to $1,000*
10% Finders fee for any member who helps sell this car :D
Engine:
OEM Subaru Block - Bored and Hone
Competition Multi angle valve
OEM STi Heat Treated Crank Shaft
Manley Turbo Tuff | Beam Rod
Wiseco Forged Pistons (100mm)
King XPG Main bearing
King XPG Rod bearing
ARP Head Studs
Brain Crower valve springs and retainers
Gate Racing timing belt
Subaru OEM gaskets
Subaru OEM water pump
Akuma TGV delete
Air pump system delete
Custom 42draft Catch Cans
Grimmspeed AOS with Catch Can
AEM Map Sensor
Grimmspeed EBCS
Perrin Radiator and Alternator cover
Cobb AP
Optima Yellow Battery
Mishimoto Performance Aluminum Radiator
Subaru OEM Super Coolant with Red Line Waterwetter
Fuel:
ID 1000 Injectors
AP Fuel Rails
Walbro 255 LPH Aeromotive pump (in tank)
Russell Fuel Lines
Fuel Lab FPR
Aquamist HSF-3 Meth Kit with remote 1-gallon tank (Mounted in the trunk)
Transmission:
2011 STi Rallispec 6-speed swap with STi linkage, prop shaft, adapter
Brand new ACT HDSS clutch with OEM flywheel
Group N Transmission Mount
SS bushings
Exhaust and Turbo:
ETS GT3076R Rotated Turbo Kit (8500 miles on it)
PTP Turbo Blanket
ETS up-pipe
ETS downpipe
Tial Wastegate
ETS 4' Intake
ETS Anodized Black Front Mount Core with Process West hot and cold side custom piping
ARK Grip CB Exhaust
AP Equal Length Header (heat wrapped)
Turbo Smart 50mm Blow Off Valve
Suspension:
Koni inserts with RCE black springs
Perrin Front and Rear sway bars
Whiteline Adjustable Ball Socket Front and Rear Endlinks
Ultimate Racing Front Strut Bar
Whiteline Rear Adjustable Toe Arms
Whiteline Anti-lift kit
Beat Rush Trans Isolators
Whiteline Steering Rack Bushings
Brakes:
07 STi Front Brembos, 08 Rear Brembos (Newly Finished with new seals) - Powder Coated Bronze
New DBA 4000 T3 Rotors
Steel Braided Lines
Brand new Stop Tech brake pads for Front and Rear (less than 1500 miles)
Wheels and Tires:
Rota T2R 18x19.5 ET38
Brand New Bridgestone Summer Tires (15k mile warranty - less than 3000 miles on them)
Muteki Lug Nuts Closed End - Black
Interior:
GT spec wheel
Redline Goods Shift Boot
Redline Goods Brake Boot
Redline Armrest
SMY Clusters with Depo Racing Boost and EGT gauges
Wicked Innovations Vent Pod with Innovative LC-2 AFR Wideband kit
Custom center console wrapped in carbon fiber
All Weather Floor Mats
Canadian WRX floor mats
OEM Red Footwell Illumination
Custom Order Carbon Fiber Door Sills
LED Lights kit
Navigation:
Alpine Full System with Navigation
Alpine INA-W910 HU with H800 DSP, PDX-V9 5 Upstage Kit
Perfect Fit 10" Box with JL 10W3 sub in the trunk
CHA 634 CD Changer
TMW SS
Exterior:
Bayson R Full Carbon Fiber Lip Kit
Carbon Fiber Rear Diffuser
OEM Hatch Spoiler with Carbon Fiber Mid Wing
Carbon Fiber Carbign Craft Rear License Plate cover
Black Grimmspeed Front Plate
Black Rally Armor with Gray Letterings
2.5 NA Hood
STi heated mirrors
Rear Reflectors LEDs
Overlay Taillights - Red
Yakima Roof Rack with Fairing - not currently installed
Headlights:
OEM Custom Painted Headlights
The Retrofit Source Light
Mini DS2 Projectors Retro Quik Kit
Philips 85122 WX Ultinon (6000k bulbs)
OEM Gen V Subaru Ballast
Mach V LEDs turn signals
Æternum
Hi, your thread was caught in the spam filter. I corrected this.
This is a quality build. GLWS.
Discussion Starter · #8 ·
As post says; will cover up to $1,000 in shipping costs for buyers not in my region. Will also cover a plane ticket for those looking to buy and drive.
Discussion Starter · #13 ·
I don't suppose there's any way this would pass CA smog... is there...
I unfortunately don't know much about CA. It has passed without problem in MA, GA and NH however. I've actually had several people from CA reach out to me about buying it so maybe they are on to something?
1 - 13 of 13 Posts
