I have a 2009 WRX and the climate controls stopped working the other day, as in none of the controls do anything anymore. The indicator lights on the dials don't come on, the blower doesn't blow, and the rear defroster doesn't work. I checked the climate control-related fuses and all of them are fine.
My A/C compressor clutch recently failed, and I ended up removing the A/C belt until I can get the compressor replaced. This issue doesn't appear to be related to the climate control problem, because the climate controls were working fine for a couple of days while the compressor belt was removed.
I'm guessing there's a wiring problem--either a short, bad connection, rodent-chewed wire, or something along those lines, but I was wondering if there were any other possibilities or if anyone else has had a similar problem. Any help is appreciated.
