1 - 9 of 9 Posts
I had a constant code for a missfire I put new plug and coilpack in and cel went off while idle but when I drive it will flash cel with code p0303 then go off again im not sure what more I can do or where to start with the new symptoms also replaced front 02 sensor
Moderator
Have you checked for boost and vacuum leaks? It's not uncommon to have either on an older vehicle.
Moderator
Well, that's one way. Usually you won't see the hole you have actually smoke test it.
Moderator
There is a misfire thread floating around, I'm on mobile so it's a pain to hunt down. I'd check there and go through what you can. If you can avoid driving it, I would.
Misfires can be caused by multiple issues, I believe even a heat shield can trigger the knock sensor and not actually be knock.
Plugs, coils and fuel are always a good first step. You can clean the MAF as well.
Discussion Starter · #8 ·
Thank you appreciate your help
2008 Subaru WRX
Took it back to my tuner and apparently it was tuned for an Sti and was constantly over boosting. All fixed now
1 - 9 of 9 Posts
