1 - 8 of 8 Posts
ive asked this question everywhere and i can no get a straight answer ...
the only downpipe ive found for the 08+ auto wrxs is a AVO and its almost 800$, can i use the manual dp or maybe a legacy gt dp ?
Hey thanks for the answer , the only thing that scares me is everyone says it "should" work ..I scared of spending money on a downpipe to find out it doesn't work ...also correct me if I'm wrong but isn't the Cobb DP 2.5" , I already have a 3" catback
It is 3" actually
When i was hunting for an answer i came across it being listed for both 08+ lgt and wrx automatic. Also if you look up the manual versions the 08+ lgt amd wrx use the same downpipes.
Sent from my DROIDX using Tapatalk
I don't see why the exhaust would affect what transmission you got, unless the transmission is bigger than the other in some form and block the exhaust path.
1 - 8 of 8 Posts
