What have you checked so far if anything
Ok I can check the lines, and see if there are any issues there, and possible replace the solenoid. I thought boost was supposed to be higher but convinced myself that I just forgot once I saw the boost stick pretty hard at 7.9-8 psi.8-9 PSI is wastegate spring pressure. Could be bad solenoid or issue with the lines.
