As title mentions, I'm having some issues with a fuel leak that appears to be coming from the drivers side near the rear wheel.
Fuel tank filler neck was replaced ~2-3 months ago
I've checked the lines as to where I see it's leaking, even replaced a few c clamps to see if it would stop. Appears to be coming from a higher point, or an area I cannot see. The only lift I have right now to see under it is my own car jack, would be nice to have a lift.
With that being said, I cannot inspect underneath any further.
I have not taken the back seat out yet to verify the hoses/connections. Should I do this before even attempting to put it on a lift and check underneath?
Doesn't seem to matter if it's hot or cold, I have not tried to run the car and see if it still leaks under idle, unless this does not matter? Doesn't seem to be pressure related, but I don't know.
Any help would be appreciated!
