1 - 5 of 5 Posts
i have 2005 wrx for sale with 134k miles on it and im asking 7999. its has a cat back exhaust on it from the former owner. not sure what type. i can put it on a lift tom and [email protected] best way to contact me or text 8563577174 my name is blaise
where is this car located and why is the hood scoop a different color
Since the seller's location is listed as Philly I'd assume the car is there. The scoop is a different color because either this owner or the previous one changed the stock scoop to one that's a 2004 STi-lookalike and never had it painted.
The 2004 STi is the only year to use a larger scoop than other years so hence how you can tell it's a 2004 model year scoop design. You can tell it's a lookalike and not OEM because the OEM one is poly and comes in white that needs to be primed and painted, while this is a grayish-tan color which is typical of the epoxy used to bind the fiberglass used to make most aftermarket ones.
1 - 5 of 5 Posts
