2004 WRX Part Out 86k miles
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
05 FXT 5 Speed Transmission 4.44 $750
05 FXT Rear Differential 4.44 $200
5 Speed Shifter Assembly with Cobb Bushings $60
EJ20x Dual AVCS Heads (Bent Intake & Exhaust Valves) $400
EJ20x AVCS Intake Camshafts $150
EJ20x AVCS Exhaust Camshafts $150
STi AVCS Intake Camshafts $150
STi Non AVCS Exhaust Camshafts $150
AVCS Metal Cam Gears: IN RH #13320AA000, IN RH #13320AA001, IN LF #13322AA000, IN LF #13322AA001 and EX LF #13323AA001 $100
AVCS Camshaft Actuator Covers #13191AA000 $10 set
Coolant Hard Lines $30
Timing Covers $15 each
JDM Engine Mounts $60
JDM Subaru Water Pump & Thermostat $50
OEM Harmonic Balancer / Crank Pulley $40
FXT Intake Manifold $100
Side Feed Fuel Rails $50
STi Fuel Pressure Regulator $35
Coilpacks #FK1086 $50 each
Axles $100 each
Transmission Crossmember $100
Rear Differential "T" Crossmember $100
Rear Crossmember $150
Power Steering Lines $50
Power Steering Reservoir $25
Power Steering Pump Bracket $15
AC Compressor $100
AC Compressor Bracket $15
AC Lines $25+
AC Tensioner $30
AC Condenser $50
Washer Fluid Tank $20
Radiator Fans $25 each
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Fork Rod $10
Clutch Line OEM $15
Pitch Stop $20
Wiper Motor $40
Wiper Linkage $30
Rear O2 Sensor #22690AA520 $35
Battery Power & Ground Cables $10
Horns $10 set
Suspension, Wheels, Tires & Brakes
Rota Gforce 17x8 +48 Wheels with 225/45 General Altimax Artic Tires $750
OEM Struts & Springs $250
Front Driver Knuckle $100
Sway bars $25 each
Rear Aftermarket Endlinks $25
Front Aftermarket Endlinks $25
Trailing Arms with Brackets $40
Front Calipers $75
Front Rotors $25
Rear Rotors $25
ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
Exterior
Silver Kartboy Front License Plate Delete $20
Rear Doors $150
Rear Bumper $150
Rear Bumper Beam $100
Trunk with Wing $150
Wiper Arms $30
Wiper Motor & Linkage $40
Wiper Cowl $25
Exterior B pillar molding with weather stripping $20 each
Driver A to C pillar trim $40
Passenger Roof Trim $40
Other Trim & Weather Stripping $10+
Interior
Dash $100
Cluster Surround $20
Door Handles $10
Passenger Airbag $50
Map Light $25
Dome Light $20
Bugeye Door Cards $50 set
More Pictures:
