1 - 20 of 117 Posts
2004 WRX Part Out 86k miles
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
EJ205 Cylinder Heads complete minus camshafts $250
EJ205 WRX Crankshaft $100
STi AVCS Left Intake Camshafts $100 #13037AA352
AVCS Cam Gears: IN RH #13320AA000, IN RH #13320AA001, IN LF #13322AA000, IN LF #13322AA001 $100
Coolant Hard Lines $30
Timing Covers $15 each
Motor Mounts $50
JDM Subaru Water Pump & Thermostat $50
OEM Harmonic Balancer / Crank Pulley $40
FXT Intake Manifold $100
Side Feed Fuel Rails $50
STi Fuel Pressure Regulator $35
Axles $100 each
Transmission Crossmember $100
Rear Differential "T" Crossmember $100
Rear Crossmember $100
Power Steering Lines $50
Power Steering Reservoir $25
Power Steering Pump Bracket $15
AC Compressor $100
AC Compressor Bracket $15
AC Lines $25+
Washer Fluid Tank $20
Passenger radiator fan $25
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Line OEM $15
Pitch Stop $10
Wiper Motor $40
Wiper Linkage $30
Rear O2 Sensor #22690AA520 $35
Battery Power & Ground Cables $10
Suspension, Wheels, Tires & Brakes
Subaru Baja Wheels 16x6.5 +48 with 215/65 Winter Tires $300
Front Knuckles $75 each
Sway bars $25 each
Front Calipers $75
Front Rotors $25
Rear Rotors $25
ABS Sensors $25
Brake Booster $50
Exterior
Passenger Rear Door $150
Rear Bumper Beam $100
Wiper Arms $30
Wiper Motor & Linkage $40
Wiper Cowl $25
Driver A to C pillar trim $40
Passenger Roof Trim $40
Other Trim & Weather Stripping $10+
Interior
Dash $100
Heater Core $75
Cluster Surround $20
Door Handles $10
Passenger Airbag $50
Map Light $25
Dome Light $20
Bugeye Door Cards $50 set
Other plastics $10+
More Pictures:
1 - 20 of 117 Posts
