1 - 5 of 5 Posts
hit the switch :p . but seriously, hit the switch, which IIRC is on the lower left hand side of the dash (and the headlamps have to be on too). or could both bulbs be burnt out?
Had the exact same problem. Fuse was fine, bulbs were good but they would not turn on when I hit the switch. Followed the wires, they were fine so I gave up and just wired them to a switch that I installed.
I had the same issue with mine, when i got the car, they wouldnt turn on. So, i tested the relay by switching them out with ones i knew worked, that was fine, then i tested the switch with my volt/ohm reader, that was fine, so when i went to look at the lights themselves, one of the bulbs were burned out, replaced it, then tried again... nothing. So i starting pullingthings apart again, and checked the voltage at the lights, and they were good and the ground was good, so i was stumped... so i put them all back together using some dielectric grease, and then for some reason, they worked! maybe you could try connecting and disconnecting everything to make sure its a snug fit!
1 - 5 of 5 Posts
