In the transfer case housing there is a plastic piece, in the workshop manual it is called an "OIL GUIDE". It looks like it fits into the end of the input shaft and the other part of it projects over the top of the 5th gear on the input shaft. I can see where the part that goes over the 5th gear will keep the sheet metal cage attached on the back of 5th gear from rotating out of position, however, it is called an "OIL GUIDE". Is there something to do with the oiling of the gears or bearings that is not obvious?
