Hey all, I was wondering if you guys could help me tackle a problem I've been having since last oil change. I had some work done on the motor by a mechanic; he did the cam seals, crank seal, valve cover gaskets, and replaced the oil pan and dipstick tube, all oem parts. Now every time I check the oil the dipstick is dry for the most part, sometimes there is a thin line of oil on one of the sides of the stick, only on the edge though, I do not know if that signifies anything. And yes, car is on a flat surface, and I checked it both hot and cold. Any ideas? Using Mobil 1 5w-30, and I added half a quart in last night to be safe, but still nothing on the dipstick. Any opinions are greatly appreciated, thanks.
