1 - 4 of 4 Posts
· Registered
Hey Guys, so i'm pretty new to the rebuild/swap process and have some questions.
I recently blew my timing belt in my 2002 wrx which caused cylinder/valve damage.
I'm going to drop a 2005 WRX engine in and was wondering what the results of attempting to twin-turbo the new engine using the stock turbo from my 2002 engine would be.
I plan on upgrading my internals a bit and upgrading the trans, but don't really know what upgrades I would really need, or if it is even worth twinning with such small turbos. I don't have the income to really splurge or do anything too crazy.
Thanks for the insight!
· Not a mod... or is he? Or, is he not?
You would have to get a bunch of custom parts made, and still have to buy other supporting mods.
It would be way cheaper and likely more efficient to buy better single and supporting mods.
· In Æternum
There is a reason that this isn't done.
The EJ platform has been around a long time. The performance paths have been well established. Stick to those.
BTW, with a 4cyl motor, a parallel turbo arrangement would only feed power pulses to the turbine every 360 degrees of the crankshaft. That's not ideal for building pressure in the turbine.
1 - 4 of 4 Posts
