1 - 3 of 3 Posts
OK so my motor is screwed I just got this car so now I need it running I was thinking of going for the less expensive 2.5 I have heard my harness tranny n everything minus ecu will work n I can put my Turbo parts on the non Turbo 2.5 I can't afford an sti swap n i know the sti is forged but its just not an option can anyone help me with any knowledge you have on this I would appreciate any Intel into this thanks
No periods makes Teflon not read posts. If you can't take the time for punctuation, I can't take the time to give myself a headache trying to read it and answer you.
Good luck with the swap.
Do it right, or not at all.
If budget is an issue:
1) Buy a used WRX motor (use compression/leakdown tests to make sure it's in good working order)
2) Buy replacement parts for your motor
1 - 3 of 3 Posts
