221 - 240 of 253 Posts
Discussion Starter #229
Since I can't edit my original post here is my Updated OP:
Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
Links to albums of individual pictures of each part are located beside each group
GC Parts
Engine & Drivetrain Pics: GC Engine & Drivetrain - Album on Imgur
• Intake manifold $50
• Rear subframe $40
• Front subrframe $80
• Rear differential carrier 'T' subframe $50
• Rear differential $50
• Transmission subframe $25
• 5 speed transmission $400
• Transmission mount $20
• Gas cap $10
• Fuel pump $20
• Fuel pump assembly $20 (1 piece broken)
• Fuel lines $50
• Fuel pressure regulator $25
• Injectors $40 set
• Clutch master $30
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10
• Power steering pump $70
• Power steering reservoir $15
• Power steering reservoir bracket $5
• Ignition coil $20
• Coil packs $40 set
• Throttle body $25
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted CV joint $25
• Intake silencer $10
• Coolant overflow tank $10
• Radiator fans $25 each
• Valve covers $40 set
Suspension & Brakes Pics: • Sway bars $40 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• Front ABS sensors $15
• Front brake caliper mount $5
Exterior Pics: • Taillights $100 each
• Driver side headlight $100
• Scoop black $75
• Hood vents blue $40 each
• Driver door black $100
• Rear bumper $100 (blue & black available)
• Front bumper beam $75
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Inner fenders $10
• Door windows $40 each
• Hood release cable $10
• Roof trim $40 each (Shipping is really expensive due to size)
• Windshield trim $25 each
• Wiper cowl $40
• Wiper motor & linkage $40
• Sunroof $100
• Driver Taillight trim blue $20
• Taillight trim black $20 each
• Quarter panel trim $10 each
• Hood prop $5
Interior Pics: • Steering Wheel $20
• Driver airbag $40
• Dash bar $50 (2 available)
• Door handle $20
• Hood release handle $5 (2 available)
• ECU cover $10
• Wire covers for inside door kick panel $10 side
• Fuel pump cover $5
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Map light $10
• Seatbelts $40 (no driver front or rear center but have the rest)
• Steering column $50
• Speaker brackets $5 set (2 available)
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Door panel bolt covers $5 set
• Gauge cluster trim $10
• Seat bolt covers $10 set of 4
• Passenger A pillar $15
• Rear heat vents $20 set (2 available)
Electronics Pics: • Knock sensor $10 (2 available)
• Sunroof harness $10 (2 available)
• Interior fuse box $20
• Engine bay fuse box $20
• Door ajar sensor $10
• Horn and cruise control steering wheel switch $20
• Hazard switch $10
• Antenna with screws $25
• Wiper switch $20
• Airbag sensors $10 each
• Airbag harness $25
• Airbag control unit $25
• Alternator to battery cable $10 (2 available)
Discussion Starter #230
GC Parts
Engine & Drivetrain Pics: • Intake manifold $50
• Rear subframe $40
• Engine crossmember $80
• Gas cap $10
• Fuel pump $20
• Fuel lines $50
• Injectors $40 set
• Clutch master $30
• Steering rack $75
• Ignition coil $20
• Plug wires $40 set
• Throttle body $40
• Cam gears $10
• Endlinks $20 set
Exterior Pics: • Taillights $75 each
• Driver side headlight $75
• Scoop black $75
• Rear bumper $75 (blue & black available)
• Front bumper beam $60
• Inner fenders $10
• Wiper cowl $25
• Sunroof frame $50
• Hood prop $5
• Driver airbag $40
• Door handle $20
• ECU cover $10
• Gas pedal $20
• Blower motor $50
• Map light $10
• Gauge cluster surround $10
• Hazard switch $10
• Wiper switch $20
