Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain Pics: EJ22 Phase I Long Block Fully Assembled $350
EJ22 Phase I Short Block Fully Assembled $250
EJ22 Phase I Heads Complete $200
EJ22 Intake Manifold $80
EJ22 Throttle Body $40
EJ22 Engine Harness $50
Crankshaft Pulley $30
Plug Wires $30
Air Assist Injector $35
Timing Covers $10
Power Steering Pump with Reservoir $75
Power Steering Pump Bracket $10
AC Compressor Bracket $10
Rear Subframe $40
Engine Crossmember $60
Rear Differential Carrier 'T' Subframe $40
Transmission Mount $20
Gas Cap $10
Fuel Pump $20
Fuel Pump Assembly $20 (1 piece broken)
Fuel Rails and Lines $50
Fuel Pressure Regulator $25
Injectors $40 set
Slave Cylinder $20
Steering Rack $50
Throttle Cable $10
Ignition Coil $30
Plug Wires $30 set
Throttle body $40
Oil Fill Neck and Cap $15
Cam Gears $10
Coolant Overflow Tank $10
Radiator Fans $25
Air Box Intake Tube Resonator $25
Suspension Pics: Sway Bars $30
Lateral Links $20
Trailing Arms $20
End Links $20 set
Control Arms $25
Exterior Pics: Rear Bumper Blue $75
Trunk with Small Wing Blue (few dents) $50
Door Windows $40
Hood Release Cable $10
Roof Trim $40
Wiper Cowl $25
Wiper Motor & Linkage $40
Sunroof Frame $40
Hood Prop $5
Interior Pics: Rear Seat $100
Steering Wheel $20
Driver Airbag $40
Dash Bar $50
Heater Core $50
Passenger Door Lock Actuator $20
Hood Release Handle $5
Wire Covers for Inside Doors $10
Fuel Pump Cover $5
Gas Pedal $20
Dome Light $10
Steering Column $50
Speaker Brackets $10 set
Tweeter Cover $10
Door Panel Bolt Cover $5
Rear Heat Vents $20 set
ECU Metal Cover $10
Electronics Pics: Knock Sensors $10
Door Ajar Sensor $10
Horn Switch $20
Antenna with Hardware $25
Airbag Sensors $10
Airbag Harness $25
Alternator to Battery Cable $10
I keep this list up to date and not a lot left from the GCs but I have Forester & GD parts in other listings
Plug Wires $30
Timing Covers $10
Rear Subframe $40
Gas Cap $10
Fuel Pump $20
Injectors $40 set
Slave Cylinder $20
Steering Rack $50
Throttle Cable $10
Ignition Coil $30
Plug Wires $30 set
Throttle body $40
Cam Gears $10
Radiator Fans $25
Lateral Links $20
Trailing Arms $20
End Links $20 set
Control Arms $25
Door Windows $40
Roof Trim $40
Wiper Cowl $25
Sunroof Frame $40
Hood Prop $5
Steering Wheel $20
Driver Airbag $40
Dash Bar $50
Heater Core $50
Fuel Pump Cover $5
Gas Pedal $20
Dome Light $10
Steering Column $50
Tweeter Cover $10
ECU Metal Cover $10
Horn Switch $20
Airbag Sensors $10
Airbag Harness $25
