1 - 11 of 11 Posts
It used to run, shitty at that with only 2/4 of its pistons but she ran, then it just stopped, it won't click or even make a soun, it's dead in the water. Replaced the battery and checked the fuses and they are all functional and so is the starter, can I get some help?
Super Moderator
Does the starter work from the key
Super Moderator
When you turn the key does the starter actually do anything or did you have to jump the starter to test it
Super Moderator
Ok, something between the key and the starter is bad.
I don't know if the relay is part of the starter but it's worth looking at. I assume when you turn the key the lights and radio come on?
Super Moderator
Ok, does the key actually turn anything in the car on?
Discussion Starter · #9 ·
, nope, nothing damn thing doesn't make a sound or anything when I turn the key
Super Moderator
Wiring in the steering column or bad wiring from the battery.
1 - 11 of 11 Posts
