1 - 7 of 7 Posts
18x7.5 +45offset 225/40/18 fit...no fit?
and i will be dropping it on Eibach Pro-kit spring.
i've had problems with doing a search for this size wheel and a 45mm offset.
any help would be appreciated.
Moderating YOU, before you had your Subaru!
+45 will be cutting it pretty close. I'd worry about the spokes not fitting over the brakes if anything. Any way you can test fit it at all?
I'm running +48 on my Volks...+46 is probably the lowest I wanna go with a 7.5" wide wheel.
they make spacers right?...somewhere along the line of 1mm - 5mm? if so, whould that solve my problem. i kinda already ordered some wheels.
There are spacers out there...the only ones I'd recommend are H&R spacers...but how big you'll need will depend on how much clearance you'll need. What kind of wheels did you order?
Discussion Starter #7
sweet! i ordered Motegi DP6's 18x7.5. well since they do make spacers ill probably get some if i have any clearance problems with the brakes. if that doesnt do it ill have to send them back or Ebay them. thanks alot for the help.
1 - 7 of 7 Posts
