1 - 7 of 7 Posts
i am planning on changing my rims to the advan rc2 with 17"x8.5 with a 45 offset. i was wondering if this will rub? its a 02 wrx and its dropped about 1.5inches all around. please message me back with what you guys think, thanks
Moderating YOU, before you had your Subaru!
It's hard to say. That should fit ok, but with your drop, I sure can't say for sure regarding rubbing. 8.5" is pretty wide for our cars after all...
90% sure it will rub.
Moderating on the run!
Not taking what tire you will be running, just the rims- you'll be change the clearance from stut housing to the inside of the wheel will be 15mm LESS
The outside edge of the wheel will EXTEND an extra 35mm
That's going from a 6.5" 55 et to a 8.5" 45 et.
Big Sky
1 - 7 of 7 Posts
