I used to pull a little trailer with my honda fit for things that wouldn't fit or were too messy to put inside. I wanted to do the same with my wrx so I purchased the hidden hitch (easy install & totally hidden) & the curt wiring harness. The hitch is on but I ran into some trouble with the wiring. For the main install you just insert the harnes between the tail light connection. You also need to supply 12v power. The instructions say to connect straight to the battery. Two things I am uncertain of. There is a fuse looking thing between the + terminal & the power to the car. Do I connect directly to the terminal or on the other side of that "fuse"(actually not sure what it is)? The second issue I ran into is how to pass the wire through the firewall. It looks like there are several spots I could use as well as a few rubber plugs I could puncture to pass through. My issue is that I don't want to rip out the dash.
Sorry if this is a repost or in the wrong place & thanks in advance for any input.
