Hi everyone.
I've been slowly upgrading the stock lighting on my 2017 WRX with LED's. The last thing to do was the high-beam DRL's. I ordered the anti-flicker module for my 9005 LED's but when I went to install them I discovered the key's don't line up. The module has I single key-channel running down the center while the male plug has two offset Key's that don't line up to the module key-channel. I've been hunting around ebay looking for the correct anti-flicker module but even the ones that say they are "WRX" or "Subaru" compatible appear to have the single centered key-channel. Can someone link me to one that they KNOW works with the 2015-2017 WRX's? I'd like to keep it under $20 if possible (most of the ones I've found are way below that).
Thanks for the help!
