So Ive searched for a similar issue for quite a while, turned up a lot of 04 WRX's, none really of the 09+ WRX.
14 WRX:
Stock Intake, New air filter
Bellmouth 3in DP Catless
Magnaflow CB
Cobb AP V2/Stage 2 91 HWG
Datalogs on my Google Drive: https://drive.google.com/open?id=0Bx8XZZUmuv8zM21zN2ZLV0FDdzQ
I was on the NWG tune before and was only getting up to 14.5 psi, tapered off to 11 towards redline. Now with the HWG it gets up to 15 psi, then tapers to 11-11.5. Datalogs are attached.
Datalogs show no knock, one thing I did see was that at lower RPM's when I get a little on the throttle the WG duty cycle will go to 70-80%, but when im at the 3500-4500 RPM floored where peak boost should occur the WG duty cycle will only get up to the mid to high 50%. Would this be the tune itself?
I have no boost leaks, pressurized the intake with 25 psi from my air compressor and it held strong. Both stock restriction pills are in there. Intake temps are great.
Any help would be great!
14 WRX:
Magnaflow CB
