1 - 14 of 14 Posts
hey guys. Can you tell me how any of you have installed a 10" box in your trunk? i had to basically lock it down to keep from sliding, but was curious if there was a velcro application or something similar?
Mine's bolted in.
are you talking the oem accessory or aftermarket?
aftermarket... also... did you get a new car. I feel like your avatar photo is different
Yes.. I have an 11 wrx sedan now, yesterday I had an 11 sti sedan..
Id use some steel l brackets on the back side and screw it down..
Upgrade :thumbup:
Discussion Starter #8
Is the STI better than the WRX?
Noooooooooooooooooo!!!!! This is not happening again in two threads I started. Both I had nothing to do with!!!!!!!
Don't worry, Tony and I were just busting balls. It won't go there ;)
I installed two 10" subs in my 09.
Thanks! I bought the box for the two subs and made the one on the right for the amp. The felt matches perfectly! The box is held down with velcro on the bottom and has not moved at all! Works great.
Discussion Starter #14
Makes sense. I will have to try the Velcro thing. Right now mine is held in with L brackets and looks so bo bo
1 - 14 of 14 Posts
