1 - 13 of 13 Posts
So I cleaned my K&N air filter for the Typhoon intake system for my 2008 WRX the
other day and when I reinstalled the air filter my check engine light kicked on, my
traction control light won't cut off (not that big of a deal :)), and my cruise control
light flashes. I didn't use any air filter oil and I made sure the filter was completely
dry before installing. I did make sure the MAF sensor wire was correctly
connected. I kind of think that a vacuum line came unplugged, but I couldn't find
one. And the engine runs fine with no noises or hesitations. I will get a code
reader on my car later this week, but I was just curious if someone has had this
problem too.
There are multiple DTCs. Without a code, our replies are like Stevie Wonder playing darts
^ That
Get the code read and then let us know what it is, or google it.
Did you get a CEL code ohioac? If so post it...
I got home after stopping to check everything out. Went through everything I could see, and then disconnected the battery. I stopped to have the codes checked the next day, but the battery disconnect erased them all.
I need to get either a code reader or a tuner.
Discussion Starter #8
Sorry for the late reply, when I got a reader on my car it said that the MAF had a low voltage and the MAF temp sensor had high voltage. After ensuring the MAF plug was tight in the sensor and erasing the code, the lights and code have not kicked back on.
It sounds like you got oil on the MAF. Just to be safe, you should remove it and clean it with electronics spray cleaner.
Just had the same CEL / Traction and blinking Cruise.
Pulled P0171.
You should start your own thread rather than thread jacking. Not only is it bad manners, but it hurts your chance of getting help, and your problem isn't the same either.
Discussion Starter #11
I don't think that was the case, only because I barely used any oil at all know it could damage via MAF sensor. I don't know for sure but I think there was just a bad connection.
What connection could be bad? Did you fix something i.e. a bad connection? If not, I'd still point to the oil. If it looks like a duck and walks like a duck and quacks like a duck then it's probably a duck.
Discussion Starter #13
I understand what you are saying and understand that it is a common problem, but I don't see that being the problem in this case. The connections I was referring to is the wire plugging into the MAF sensor. But all that matters now is that there is no CEL and all is running perfectly. Long live Subaru and Club WRX.
1 - 13 of 13 Posts
