1 - 20 of 23 Posts
Whats Up!
I Sold My 15' FRS to go back to Subaru! I had been missing the AWD and Turbo for 3 years. Although I must say that it has WAY better handling.
Lets cut to business :)
Bought a 06' True Canadian STI (speedo in KM/H and heated seats ;) ) Our winters are bad ok? haha
2006 STI Project WRB
Installed Pieces
--Interior--
-Prosport 60mm Boostguage
-LED kit Diode Dynamics ->
  • Dome HP6 Bulb (103lumens) Blue - 5$
  • Trunk HP5 (92lumens) Blue - 8$
  • Map HP6 (130lumens) Blue - 10$
  • Glovebox SMD1 (16lumens) Blue - 2$
-Weathertech Mats - 128$
--Exterior--
-Paint OEM WRB - 7000$
  • License plate HP5 (92lumens) White - 8$
  • Backup T20 7440 White - 10$
  • Rear Turn T20 7440 Yellow - 10$
  • Front Turn 7443 Switchback Yellow - 10$
  • LED High Beam 6000k - 30$
-Rally Armor UR Mudflaps Black w/Blue Logo - 250$
-Window tint
-Lachute Radiator Shroud
-RPG Trunk Wing Spoiler (Deleted)
-OEM wing - 0$ (Switched with Someone Else)
--Suspension--
-Mags 17x8 +53 BBS Forged Gold
-Mags Rota Grid 18x9.5 +35
--Power--
-Grimmspeed PNP OEM Header
-Air/Oil Seperator Catch Can
-Cobb AccessPort V3
-Perrin Silicone Air Inlet
-Perrin Short Ram Intake
-SPT 3'' Catback
-Lachute 3'' Downpipe
-Lachute J-Pipe Spacer for Rear O2
-TGV Delete
-MAF Delete
-JECS 850 Side Feed Injectors
-OEM Water Pump
-OEM Nitride Crankshaft
-OEM 12mm Oil Pump
-Dw200 Fuel Pump 255Lph
-Manley 100mm Forged Pistons
-Manley Connection Rods
-ACL Main + Rod Bearings
-OEM AVCS Cam Gears
-Timing belt Gates racing
-Cometic Head Gasket Set
-Grimspeed 3 Port Boost Controller
-Bloutch 20G Turbo XT (72mm)
-Grimspeed 4'' TMIC
-Invidia Uppipe
-Grimspeed Crossover Pipe
--Transmission--
-Kartboy ShortShifter
-OEM Wheel Bearings
-Bully Clutch Stage 3
--Sound System--
-Bluetoot Head Unit - 265$
-Infinity 6''1/2 Front Speakers (250W)
-Pionneer 6x9'' Rear Speakers (450W)
-Alpine 10'' Sub (700W)
-Alpine Class D AMP
Total Spent (aside from car price) - 7756$
Will be keeping updates on this thread whenever I have changes :)
Pics of first mods soon
Discussion Starter · #2 ·
Update #1 :)
Car doesn't have the OEM wing... so I asked around and someone was willing to trade for 0$
Car is clean under but it needs a Paint Refresh all around so I went All Out
Asked for a COMPLETE paint Job:
All trims removed (skirts, wing, window seals etc)
Black housing up front
And since I had a crack in the windshield and had to change it anyways I asked them to take the ceiling mat and paint it black. I will be painting the rest of the grey trims myself but I knew the ceiling wouldn't just come out from the doors so it was a good opportunity to do it.
While I'm waiting I bought a couple things:
Weathertech Mats
LEDs ALL around
Rallye Armor mudflaps
and change the 1Din Radio for a 2Din with Blutooth to freshn it up a little :)
The power output is great for now (practically doubled my horsepower from my FRS)
so I will be attacking the suspension after the paint is done
Discussion Starter · #3 ·
Update #2
Still waiting and damn its a long wait!
But here is a little tease and update on stuff received and paint process
BooSTIng
Impressive man. It is looking good. Love this body style STi.
I feel you on the wait part. My 12 STi limited sedan spun a rod bearing last September. It has been at the shop getting a built motor put in to it for a little over a month. Hoping to get it back soon!
Keep up the good work and updates!
Discussion Starter · #7 ·
Update #5
Received the car Yesterday and OHHHHH BOY! :love:
Amazing job they did in restoring that beauty!
Installed all the stuff I had ordered
More pictures soon :)
More mods soon as well :sneaky::geek:
BooSTIng
Looks great dude. Very clean. Making me miss my STi. I cannot wait to get it back from the shop!
Super Moderator
That paint looks intense in the sun. Beautiful car.
Great project!
This is one of the actual "build" threads unlike the hundreds on IWSTI.com filled with almost nothing but LED light and badge swaps.
Discussion Starter · #13 ·
Update #6
That ?? ABS light is ticking me off ?
So I wanted to change the two abs sensor to the rear and the hand-brake wires
Turns out I needed to change the drum brake pads too ?
And uppon reinstalling one caliper, threads had to be retapped and helicoiled; Someone didn't put the right bolts in and had a lot more fun with the E-Brake than announced ?
Anyways
Looking forward to @Lachuteperformance 's SubieFest on August 24th at ICar Mtl!
Got some 1/4Mile times I wanna beat!
Super Moderator
What kind of power. That number doesn't seem that far off because you still have to account for the driver error. Most published numbers from the factory are ideal conditions
Discussion Starter · #16 ·
The Power band is in the first pictures (dynograph)
Should be in the 12s easily since I have +/-100hp over stock and they; like you said, in ideal conditions, run 12.6 stock
Edit: Cobb doesn't account for wheelspin or wheelbounce
Super Moderator
You are not 100whp over stock maybe 60 to 70 as they average 220 at the wheels from the factory. 14.xxx is probably realistic on an actual track.
If wheel spin was an issue Cobb would have listed your numbers much faster than 14
Discussion Starter · #18 ·
Should be downwards of 13 secs normally like 12.4-13.0 range
We shall see soon enough ?
Edit: Pull was done with:
no launch
no FFS
and on a secondary(notsticky) road
1 - 20 of 23 Posts
