1 - 6 of 6 Posts
Hello, My 05 WRX died driving to work the other day. Now it cranks but will not fire. Fuel pump seems to work properly. I have replaced the crank and cam position sensors but still no start. Any ideas on what to check next?
Thank you in advance
Does the timing belt still exist?
Super Moderator
Check fuel to the cylinders, spark at the plugs, and compression.
Discussion Starter · #5 ·
Timing belt is intact, no missing teeth or visible damage. Fuel pump seems to work, I can hear it pressure up when the key is turned on or the peddle is depressed. I have power to the caps but have not spark tested yet.
Discussion Starter · #6 ·
Should also mention it has a butt-load of miles on it, 280k+. It is fairly recently on its 3rd timing belt, about 500 miles ago
1 - 6 of 6 Posts
